engine problem
Old Dec 19, 2007 | 07:23 PM
56f100pickup's Avatar
56f100pickup
Exclamation engine problem
i have a 86 f150 wih a carberated 302. i recently blew a head gasket and it over heated. i put new gaskets on it and the heads didnt looked bad. i started it up and it ran fine until i put it in reverse then it got rough and didnt want to run right. if anybody has an idea of what is wrong it would help alot.
Old Dec 19, 2007 | 11:42 PM
gearhead351's Avatar
gearhead351
Well a little more info then that would be a little helpful. When you put it into reverse, did you rev it? pops, squirts, pings? Ya might have fouled plugs if you didnt change them.
Old Dec 19, 2007 | 11:47 PM
condolan's Avatar
condolan
Could be a lot of things.
Coming to mind at the moment:
-vacuum leak
-maybe the heads or block aren't okay (did you check them with a level and feeler gauge?)
