Power Steering Pump
Old Dec 19, 2007 | 03:12 AM
dawolverine's Avatar
dawolverine
Power Steering Pump
Hi, I need to get a power steering pump and bracket etc to fit the 1979 Ford 302 engine that is in my truck.
Does anyone know what type of pump will fit and where I can find one?
Old Dec 19, 2007 | 08:02 AM
51dueller's Avatar
51dueller
Finding a pump will be easy as it was the same from 1978 to the 90's. The bracket might be a different story. Is this the one with the 3 sliding bolts and the one adjuster bolt?
Old Dec 19, 2007 | 11:56 AM
dawolverine
Not sure, but it looks like there are 3 mounting holes on the front of the block where it would mount
Old Dec 19, 2007 | 12:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I would expect you could use any drive belt system, pump, and mounting brackets from any 302; pump location and mounts varied from Mustangs to TBirds etc. Just use the whole drive system, pump, and mounts, don't try to mix and match.
