simple taillight replacement
Old Dec 18, 2007 | 10:34 PM
bass3006's Avatar
bass3006
Angry simple taillight replacement
Earlier today, I tried to replace the taillight/blinker bulb on my 2002 f350. I dropped the tailgate, pulled the 2 small bolts/screws out, but then couldn't get the taillight housing free... It was loose, but it just would not come off. I know this is normally something straight foward and I have done it on other trucks and cars. What is the secret I am missing?
Old Dec 18, 2007 | 10:38 PM
white Buffalo's Avatar
white Buffalo
Just gotta pull it a little harder. I thought the same thing the first time I replaced a bulb, thought I was gonna break it.
Old Dec 18, 2007 | 10:42 PM
jeff7825's Avatar
jeff7825
I always take a flathead screwdriver and gently use it to pry the light out. Just don't pry too hard against the bed and chip the paint or put a dent in it. I've never had a problem using this method.
Old Dec 18, 2007 | 10:43 PM
nhill2090's Avatar
nhill2090
it will feel like your gonna break it but just keep pulling
Old Dec 19, 2007 | 03:11 AM
ron's power stroke's Avatar
ron's power stroke
after you remove the screws..pull strait out..do not twist it out or it will break the plastic taps... it does pull hard but if you pull strait and hard it shouldn't break.. before you put it back in..put a dab of grease on the plastic clips and put it back together..that way the next time it needs to come off..she will pull out a lot better..
Old Dec 19, 2007 | 03:07 PM
bass3006's Avatar
bass3006
Thanks a lot for the suggestions people, I will try them soon!
Old Dec 19, 2007 | 03:21 PM
JoeTrotter's Avatar
JoeTrotter
You could do what I do - slide sideways into a tree, then you dont even need to open the tailgate to get to the bulbs!
