differential cover replacement
Old Dec 18, 2007 | 06:07 PM
bearsf150's Avatar
bearsf150
Question differential cover replacement
what is needed to replace the differential cover on a 2000 F 150 4x2
Old Dec 18, 2007 | 06:34 PM
aurgathor's Avatar
aurgathor
Another cover, gasket or some silicone, proper size hex wrench or socket, gear oil, pan for old oil, etc.
Old Dec 18, 2007 | 07:08 PM
projectnitemare's Avatar
projectnitemare
Also add some paper towels, a razor blade/scraper to remove the old silicone, and some brake cleaner to clean the sealing surface. It's pretty straight forward. You will need a rachet to remove the fill plug on the front side near the pinion.
Matt
