horrid mpg
Old Feb 1, 2008 | 10:59 PM
  #31
alfasteve's Avatar
alfasteve
Hey All,
Last week I installed a new oxygen sensor, and a new ECU from a 1989 (same year as my van) 302 4x4 truck with AOD. Mine has a C6.
The results? Pretty much the same, although now she runs great when cold, but after a few miles of warming up, she seems to run too lean. She suffers in part throttle acceleration, what I'd call a lean surge. Pressing on the gas doesn't produce any forward momentum, she just labors harder and doesn't pull very smoothly. No backfiring or anything, just feels starved for gas. If I floor it, she pulls smoother, but still feels as if the timing is retarded. Again, when cold (and presumably richer) she doesn't have this weak part-throttle condition.
The engine still starts perfectly hot or cold. Idles fine. Taking off from a start is fine until you push the throttle a little heavier, then the lean condition makes itself known.
My check engine light has not come on since I did the swap. I figured I'd give it a couple tankfuls of gas to let the new ECU 'adapt' to its new surroundings, but nothing seems to be changing. I am on my 2nd tankful now, ready for my 3rd. Gas mileage does not appear to be any better.
Is there a way to bring the ECU back to its initial calibration? Any other thoughts?
Thanks again in advance,
Steve S.
Seattle, WA
Old Feb 8, 2008 | 03:42 PM
  #32
spikedog's Avatar
spikedog
You can pull the fuses that go to the ECU, or pull the negative battery cable off for about 5 minutes. With the fuse route, you don't lose your radio presets, but you have to pull a couple of fuses (don't ask me which ones). That should get your ECu back to default.
Old Feb 9, 2008 | 01:37 AM
  #33
alfasteve's Avatar
alfasteve
Thank you for that. So, when my Ebay ECU arrived, was it in its default condition, having been disconnected from any power source for at least a few days?
Steve S.
Seattle, WA
'89 E250
Old Feb 11, 2008 | 08:28 AM
  #34
spikedog's Avatar
spikedog
Quite possibly, yes, it could have been in default. The aforementioned tricks are only good if you are starting over after a repair.
Any leaks around the intake manifold? Try spraying some carb cleaner around the gaskets to see if the idle changes.
TinyWonder
Jan 10, 2016 06:37 AM
tomfoolery
Dec 5, 2014 09:41 AM
GB SISSON
Feb 26, 2014 06:13 PM
GB SISSON
19
Feb 26, 2014 05:27 PM
powerstroked162
6.4L Power Stroke Diesel
36
Jul 31, 2007 10:43 PM
