help 4wd
Old Dec 18, 2007 | 12:50 PM
bigfrank123's Avatar
bigfrank123
help 4wd
Just Found This Site The Other Day. We Got Some Snow Over The Weekend And I Pushed The Button On The Dash And Nothing Would Work Do I Need To Get Out And Press Something Outside
Old Dec 18, 2007 | 12:55 PM
FordTrucksRockMySock's Avatar
There should be a red and a green button on the transfer case to lock the hubs in and out. Try pushing the red button.
Old Dec 18, 2007 | 12:58 PM
bigfrank123
i've never had a 4x4 before. i have no idea where the transfer case is, but if you have a picture that would be great. what do you think is broken?
Old Dec 18, 2007 | 01:01 PM
I think its underneath somewhere... I don't really know.
Old Dec 18, 2007 | 01:14 PM
Drew2010's Avatar
Drew2010
Welcome to the site. Sounds like you have a lot to learn, This site will defenetaly help. The transfer case is bolted to the rear of the transmission. It will have driveshafts coming out of it. one of to the side goes to the front axle and the one directly behind trans and transfer case goes to the rear axle. And since it is new to you look in the middle of the front wheels there might be a dial you need to turn to engage the hubs.
Old Dec 18, 2007 | 01:18 PM
bigfrank123
I'll Have To Look Later One Of My Friends Said Something About The Wheels
Old Dec 18, 2007 | 01:21 PM
fordman1090's Avatar
fordman1090
What are some details about your truck, year, engine, trans, so on.
And first does the light on the dash light up? If it does Check to see if you have manual or auto hubs. The Manuals will have a place to turn in the middle of the front wheel's, you turn one way to lock them and the other to unlock them. If they are auto hubs it will just have a ford 4X4 auto locking hub decal on it and will automatically lock when its put in 4x4.
If it doesn't light up, check the fuses in the fuse panel in the cab. there shoul;d be a label on the back on the removable panal. One should be labeled electric 4X4, if that fuse is good then it might be the shift motor which is a fairly inexpensive and easy fix.
As for the red and green button, i dont have electronic shift and have never heard it referred to before. The hubs work independently from the transfer case.
Good luck
Last edited by fordman1090; Dec 18, 2007 at 01:26 PM. Reason: Didnt explain vary well
