is ther any other way i could pull the motor out with out taking of the cab.....(maybe pull off the core support and the front end and pull it out that way)
Yes, removing the bumper, intercooler (everything in front of the motor) is the most common way used by people w/out a lift. I'm sure some w/ a lift have done it as well for various reasons. Most say it cuts the r & r time about in half if you lift the body, however, it will tie up the lift until the 6.0 is back together. Good luck and get ready as a "noseless" truck sure looks bad.
