Explorer Transmission
Old Dec 17, 2007 | 10:28 PM
zmartin's Avatar
zmartin
I have a 2004 Ford Explorer and it has been great so far wt no problems. However recently the transmission has been hesitating while upshifting and jerks when placed in reverse. Was just curious if anyone else has had this problem or if Ford has a tsb out on this issue?
Old Dec 17, 2007 | 10:40 PM
CTford's Avatar
CTford
Many 2004's were filled with the wrong fluid from the factory. I'd check this first. You can check the TSB's at www.nhtsa.gov and then compare VIN numbers.
