Ignition problems?
Old Dec 17, 2007 | 06:56 PM
Born24wheel's Avatar
Born24wheel
Ignition problems?
Hi, I have a 86 F150 I am doing a carburetor conversion on, from efi. After doing the installation, I have no spark. Currently, I already installed the carb and every other component. Everything is wired in, I am using the duraspark box, coil, and vacuum distributor. I ran the red/lightgreen (crank and run) wire to the box and coil, and the distributor is wired to the other side of the box as well. I am using the dark blue box with a new coil and distributor. Am I missing something, is it the wrong box, is there something else I need to hook up? Thank you for any help.
Old Dec 19, 2007 | 12:12 AM
Franklin2's Avatar
Franklin2
Get a testlight and make sure you have voltage on the coil + while cranking the engine.
