Throttle plate question
Old Dec 16, 2007 | 11:06 PM
tippmann87's Avatar
tippmann87
I was reading up on the EGR disconnect instructions and had a quick question. Matt talks about having to remove the throttle plate on some years, mainly the '04s. I have a 2006 and was wondering if mine has a throttle plate?
Old Dec 17, 2007 | 12:35 AM
gtdan01's Avatar
gtdan01
No yours does not. Only 03 and 04 have throttle/EGR plates.
Old Dec 17, 2007 | 12:40 AM
tippmann87's Avatar
tippmann87
Thanks......I'm going to unplug the EGR tomorrow then
Old Dec 17, 2007 | 07:35 AM
coloradokid's Avatar
coloradokid
What does a throttle plate do? Any benefit in removing it on a stock 03 6.0 PSD?
Old Dec 19, 2007 | 09:27 PM
gtdan01's Avatar
gtdan01
I would to say that it helps control the flow of air into the manifold to account for the EGR gases being flowed into the manifold at the same time. I removed mine from my 04 and didn't notice much of a difference but I had deleted the EGR cooler at the same time so it would have been hard to tell. Only thing I noticed is now I get the famous turbo fart/whooshing noise.
Old Dec 19, 2007 | 10:28 PM
a-rod's Avatar
a-rod
I removed the throttle body on my 04 and replaced it with an "05 newer" power elbow. Just the other day I put the throttle body back in with the stock intake elbow and I notice more turbo lag. Mines a cali truck so it threw the CEL removing it.
Old Dec 19, 2007 | 11:02 PM
gtdan01's Avatar
gtdan01
Yea my 04 also set off a check engine light when I removed the throttle/EGR plate.
