cam kit?
Old Dec 16, 2007 | 03:54 PM
livalot4's Avatar
livalot4
cam kit?
i got a 352 in my 66' and i put a 390 4 barrel intake manifold on it, and i was wondering what size of cam kit i should get to make up for the fuel difference? it originally had a 2 barrel manifold on it?
Old Dec 16, 2007 | 04:01 PM
garbz2's Avatar
garbz2
Cam as in cam shaft or cam on the acellerator pump on the carb?
Garbz
Old Dec 16, 2007 | 04:03 PM
livalot4's Avatar
livalot4
sorry cam shaft is what i meant
Old Dec 16, 2007 | 04:12 PM
garbz2's Avatar
garbz2
Cart before the horse...you have to pull all the intake back off to install a cam. The pushrods go through the intake on the FE. and need to be out to remove the lifters.
For a 352 it will wake up with a car pattern 352 390 cam from the mid sixties and a dual roller timing chain. Unless you want lopey idle then your 352 is not the best choice, as additional mods need to be made in the valve springs porting and such.....
Dont over carb the 352 either. A 500 CFM to 600 CFM carb is way more than enough.
Garbz
Old Dec 16, 2007 | 04:17 PM
livalot4's Avatar
livalot4
not the right choice keeping the 352? i just want to know exacly what i need to do to get the right power out of it.
Old Dec 16, 2007 | 04:34 PM
garbz2's Avatar
garbz2
See above. to get max power out of a short stroke 352 use one of the factory car cams, not a truck cam.
Putting a big cam in a 352 is sort of usless as it has a lot of mass to over come by its design to make power. It is limited by its displacement.
A comparable 390 with a stroke of .25" longer will run rings around a 352.
Post over in the FE forum on this site and the Gurus can point you in the right direction.
Old Dec 16, 2007 | 04:41 PM
starmilt's Avatar
starmilt
the old 352 four barrel motors were no slouches pretty peppy and rapped quick suspect some differance in valves and porting tho.
Old Dec 16, 2007 | 04:47 PM
garbz2's Avatar
garbz2
They used the same heads C5ae's low risers, some cars....But a four barrel was only offered in cars with a car profile cam. the truck cams are different to make bottom end torque.
60 or 61 starliners had the factory hi po 352 360 horse, but these are real rare.
Garbz
JRB65
23
Dec 12, 2012 10:27 AM
80 f-150
Sep 5, 2011 11:47 PM
Needsoles
May 24, 2009 02:46 PM
livalot4
22
Dec 27, 2007 01:18 AM
Jebadiah04
21
Feb 18, 2005 02:08 PM
