Explorer Problem
Old Dec 16, 2007 | 12:43 PM
diesel2008's Avatar
diesel2008
Explorer Problem
I have a 01 Ford Explorer Sport with starting issues. When I start it up, sometimes it starts with no problems and sometimes it takes a few tries and I cant figure out why it does this. I am not a mechanic so all I can do is guess maybe tune-up I dont know. Any ideas would be gladly accepted. Thank you.
Old Dec 16, 2007 | 02:42 PM
Backin72's Avatar
Backin72
Could be the fuel pump relay. When they start to go bad, they are intermittent then quit altogether. When you turn the key to the on position, do you hear the fuel pump prime for about 1 sec.?
Try this little test before starting your truck. Turn the key to the on position. Listen for the fuel pump to prime. If you hear it prime, start the truck. If it doesn't start, you know it's not the relay. If you don't hear it prime chances are it is the relay. Change it out, about $10 at your local parts dealer. If you continue to have problems after that, could be the fuel pump itself, a bad ground or a clogged fuel filter.
BTW, what's the mileage? Should have your first tune-up around 100k and use original Motorcraft plugs and wires.
Old Dec 16, 2007 | 04:34 PM
diesel2008's Avatar
diesel2008
I bought it with 121k. It has 145k now so I dont know if it had a tune-up or not. But I do know this problem just started. I even tried to keep the RPM's up so I can put it in gear to drive and that will work but when I take my foot off the gas(even while driving) the RPM's drops and the truck shuts off.
Old Dec 16, 2007 | 05:38 PM
aquanaut20's Avatar
aquanaut20
classic diagnosis of a bad IAC, try cleaning it.
https://www.ford-trucks.com/forums/1...rol-valve.html
Old Dec 16, 2007 | 07:16 PM
Backin72's Avatar
Backin72
I'd say so too. A little info goes a long way. ;-)
Old Dec 16, 2007 | 07:22 PM
diesel2008's Avatar
diesel2008
is it easy to replace and how much would it cost?
Old Dec 16, 2007 | 07:37 PM
Backin72's Avatar
Backin72
Not sure of the cost, but I think it's somewhere around $150. Someone will correct me if I'm wrong. It's super easy to replace though. This should help.
https://www.ford-trucks.com/article/...r_IAC_Fix.html
Old Dec 16, 2007 | 08:29 PM
diesel2008's Avatar
diesel2008
Will this also cause rough idling and poor gas mileage?
Old Dec 16, 2007 | 11:09 PM
aquanaut20's Avatar
aquanaut20
There are many things that will increase the fuel consumption...
complete the cheap/free fixes first.....
  1. Scan for codes.... post any here
  2. check fuel pressure, static and running
  3. clean IAC and MAF
  4. Check and adjust TPS
  5. Check and clean EGR
Post the results.... P
Old Dec 17, 2007 | 04:50 AM
diesel2008's Avatar
diesel2008
i bought a new iac valve. I see that it comes with a gasket. Is there anything else I need in order to install the new one. I am not a mechanic but it looks easy to do but looks can fool you sometimes.
Old Dec 17, 2007 | 04:55 AM
marragtop's Avatar
marragtop
Easy repair. Read this link--> https://www.ford-trucks.com/article/...r_IAC_Fix.html
Old Dec 17, 2007 | 05:32 AM
diesel2008's Avatar
diesel2008
Do I need any lub or sealant etc. I am sorry for all of the ?'s. This something I dont do on a regular basis.
Old Dec 17, 2007 | 05:54 AM
marragtop's Avatar
marragtop
No, you shouldn't need to use Permatex or any other sealant, just make sure both surfaces are clean.
Old Dec 17, 2007 | 05:59 AM
diesel2008's Avatar
diesel2008
So just take off the old iac and replace it with the new one with the gasket that it comes with. That's it?
Old Dec 17, 2007 | 07:53 AM
Backin72's Avatar
Backin72
That's it. Let us know how it goes.
