Cluster lamps
Old Dec 15, 2007 | 09:33 PM
madsonp's Avatar
madsonp
Cluster lamps
Are the lamps that illuminate the instrument cluster replaceable. If so where can these be purchased other that through the dealer ?
Old Dec 15, 2007 | 10:12 PM
FTE Herman's Avatar
FTE Herman
I think the spec on them is in the owner's manual isn't it? With this number you should be able to go to any auto parts store. In fact, they can probably look up the number for you.
Old Dec 16, 2007 | 04:31 PM
maldbwmjr's Avatar
maldbwmjr
I just changed these this weekend - talk about a nightmare to get to! You have to remove so many covers and then twist the headlight switch to full on, pull out the switch, re-insert it 180 degrees opposite of where it's supposed to be, then pull out the whole headlight switch assembly and uncoupled the connecters in order to remove the panel. I finally pulled out the instrument cluster and found that it uses five # 194 bulbs. 3 of them were burned out but I replaced all 5 anyway as they were 10 years old - I don't want to pull that cluster out again - if ever. Good luck.
Old Dec 29, 2007 | 05:50 PM
madsonp's Avatar
madsonp
Did mine today, I didn't think it was to bad. the cluster was easier to pull than those on the old cars that had a speedometer cable you had to pull loose before you could get the cluster out. Anyway thanks for the info.
Yahiko
Mar 30, 2013 04:40 AM
Vin Man
Electrical Systems/Wiring
May 29, 2012 11:35 PM
Sedan300
Feb 20, 2010 02:16 PM
mbritt
Nov 19, 2006 07:13 PM
falconer
Aerostar
Dec 3, 2005 06:08 AM
