egr valve blues....
Old Mar 26, 2001 | 05:16 PM
quadna711's Avatar
quadna711
egr valve blues....
i'm having problems getting my '79 F-250 to get through emissions out here in delaware. it hasn't had an egr valve since the day i bought it - only a chunk of metal bolted over the valve's plenum. when i picked up a valve at the local store, the directions tell me to use the old valve to determine size and thickness of the ringed washers to install in front of the valve. now, without an original to compare it to, how can i figure out which ones are correct? just for the heck of it, i went and put it on without any and it runs like crap (go figure), regardless of timing and carb adjustment. local dealer just laughed at me when i posed them the question and the parts store kid had 'honda civic' written all over his face. anyone out there remember which sized hole washer and cup washer gets installed or at least where to look for the info? it is a 3/4 ton, 4 speed manual on the four, straight 6 4x4. that was all the info the store needed to narrow the selection of valves down to fit my truck so hopefully it will give me somewhere to start. thanks
1979 F-250 4X4 300 I-6 4spd manual 3" lift w/35" grabber mt's
Old Mar 27, 2001 | 11:39 AM
woodbutcher's Avatar
woodbutcher
egr valve blues....
I'm lucky enough to have an all Ford truck junkyard in my area, when I had to 'replumb' some emissions recently, they were good enough to let me wander around 'researching' similar vehicles. I ended up putting a good looking used EGR valve and tubing setup on and it worked great. I believe those washers are flow orifices sized for the application and you may be able to find the right ones that way, good luck.
Old Mar 30, 2001 | 10:48 AM
quadna711's Avatar
quadna711
egr valve blues....
thanks woodbutcher for the reply,
i tried the yards around here and they have nothing for me. all the trucks in there are injected animals and have different types of setups than i do. all the older carburated models have been either picked clean or just have the valve removed and a metal bar bolted over the holes (like mine was). i'll keep looking in case anything new shows up though. thanks again.
quadna711 '79 F-250 4X4 300 I-6 4speed
Old Mar 30, 2001 | 07:26 PM
ford man dick's Avatar
ford man dick
egr valve blues....
