Is this a possible EGR problem
Old Dec 15, 2007 | 10:20 AM
Rock2005's Avatar
Rock2005
2006 F250 6.0L Excessive smoke from exhaust and no power at all on tip in. It does however clear up at times where there is no smoke at all and plenty of power from a stop. Also when I tip into the throttle the exhaust system goes almost silent then it starts billowing grey looking smoke. Thanks for any help you can give me.
Old Dec 15, 2007 | 08:11 PM
20046.0PSDX's Avatar
20046.0PSDX
Sounds like a good chance its some "sticky" VGT issues as this can result in excessive lag and/or smoke and symptoms can be intermittent. Get it checked for under/overboost issues. Could also be injector problems as well. Either way if its that bad it should throw some codes.
Amp
Old Dec 16, 2007 | 08:41 AM
Rock2005's Avatar
Rock2005
I have been watching the boost and it has been 24lbs to 27lbs. It has been making this boost for 52,000 miles with no problems. I wonder though why the MBRP exhaust system gets VERY quiet when I am having the problem? I don't think an injector problem would make the exhaust note change like that. Could the VGT change the exhaust note?
Old Dec 16, 2007 | 09:56 AM
big inch's Avatar
big inch
That sounds more like a sticking egr valve.
