Disabling PATS light
Old Dec 15, 2007 | 12:50 AM
mcjones44us's Avatar
mcjones44us
When I got my PCM from DP-Tuner I had them disable the PATS system. They sent me a diagram showing what to disconnect in order to keep the theft light from flashing.
I'm wondering if anyone has disabled their theft light, and what's the best method to get to the connector; via the panel under the steering wheel, via the trash bag holder thing or maybe after taking out the glove box....? (help)
Old Dec 15, 2007 | 02:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
The light is on the gauge cluster. Seems to me the easiest would be to pull the dash and then the cluster and remove the connector. Can't imagine going through the glovebox would be easier.
Old Dec 15, 2007 | 03:31 PM
mcjones44us
Smile
Hey Monsta - You're right, but the wiring diagram I have from DP-Tuner shows a connector that should be disconnected further toward center of the firewall. It's one of those 3D-cutaway drawings that is a little confusing to look at. I should probably just call DP-Tuner, but I figured others had probably disable their pats. I guess I could always just put a piece of electrical tape over the theft light.
Old Dec 15, 2007 | 05:31 PM
aklim's Avatar
aklim
Why though? I have PATS enabled and it doesn't hurt anything.
ScaldedDog
Aug 3, 2021 11:14 PM
BeachEx
May 21, 2014 05:29 AM
RobbyMartin
Computer Chips & Tuners
Feb 25, 2010 07:18 PM
