which rims will fit???
Old Dec 14, 2007 | 07:36 PM
02sd's Avatar
02sd
Question which rims will fit???
I have some brand new 17" tires and am wonderng what factory rims will work on my 2002 superduty crew 4x4 lariat, I would like to use an aluminum rim from the newer years, but there seems to be a problem due to the change over to coil springs from leafs as the 2002 uses, is this true?? If there isn't a rim in 17" that I can use does anyone know what rims will fit on the 2002 that are used on the newer trucks, Thanks.
