Sponsored by: Auxito
anthor need help with tires thread ;)
Old Dec 14, 2007 | 04:12 PM
3LacK_Label_'s Avatar
3LacK_Label_
ok , i did a search but i sort of need specific info..
I have a 2002 F150 FX4 offroad.
I was wondering what the largest tire size with 17 inch wheels i could fit with out any problems..
I really like the Micky Thomson Baja MTZ.. And could you post picturs of your pre 04 F150's with large tires on them plz..
TYVM
PS: Any tire and wheel combination help would be greatly appercaited.
Old Dec 14, 2007 | 05:19 PM
galaxie641's Avatar
galaxie641
285/70/17 I'll see if I have any pics of when I ran them.
Expect no rubbing but increased brake wear as well as the front suspension getting worn faster and U joints going out faster.
Old Dec 14, 2007 | 05:30 PM
3LacK_Label_
thank you very much
Old Dec 14, 2007 | 05:43 PM
xtrford's Avatar
xtrford
You could even go to a 295/70r17 nitto as well.
Old Dec 15, 2007 | 12:38 PM
3LacK_Label_
even with mud terren MT MTZ?
Old Dec 15, 2007 | 01:43 PM
galaxie641's Avatar
galaxie641
I've heard some not have rubbing issues and some do with 295's. Every tire maker is a bit different not every 285 (295)/70/17 will measure exactly the same.
Old Dec 15, 2007 | 04:14 PM
3LacK_Label_
here is the tire and wheel set-up i;m going with.. tell me if these r going to work i dont see a problem but just to make sure before i click the pay button.
going with the Pro Comp Xtreme Mud Terrain LT285/70R17
Overall Diameter = 33
Tread Depth = 18/32
http://www.4wheelparts.com/prodDetai...artNo=PCT67285
and the wheels..
Pro Comp Xtreme Alloy Series 7005
17x8 -- 5 x 135
http://www.4wheelparts.com/prodDetai...o=PXA7005-7835
thank you
Old Dec 15, 2007 | 08:27 PM
3LacK_Label_
^^ bump?? ----
Old Dec 16, 2007 | 10:22 AM
galaxie641's Avatar
galaxie641
Tires are fine rims have some questions, these trucks are hub centric not lug centric also you need to find out what the stud holes size is; '97 and '98's have 12mm studs '99+ have 14mm studs.
Old Dec 16, 2007 | 11:35 AM
shoot5345's Avatar
shoot5345
Can Any One Tell Me If Ther Is A Way To Find Exact Production Figures On A Specific Model.ie: 97 To 03 F150,standard Cab,flair Side,fx4,4x4,5.4l,auto.(my Truck).i Had A Hard Time Finding This 03.
