Afraid to Ranger
The problem is.....it is a little truck. I am afraid of it because the gas mileage might not be any better than on a larger truck. If this would be the case, then I would prefer the larger truck....I think.....!
Too, I have heard that the smaller trucks like the S-10 and the Ranger are a lot more dangerous to drive that the larger ones. I would prefer the smaller truck because my garage is a little tight with two full sized vehicles in it.
I guess I just need some encouragement regarding this dilemma. I am in need of another vehicle at this time as the old one has seen better days. Thank you in advance for any comments......O.K.
and that little things moves!
and it does alot more than you think it would be able to for a little truck.
but my only problem with it is that its very light weight and if you dont haev decent tires it will slide if you give it to much gas in the rain or snow.but mnot alot.
but i would recomend them to you for sure!
they are great little trucks
Go get it and enjoy it.
There are multi page "MPG" & "Miles on your Ranger" threads on this forum, that can give you some feel for what you can expect from the Ranger your considering, in the way of fuel consumption with various engines, trannies & rear end ratios & how long & well they last.
Drive it over roads your familiar with, if it's right for you, it'll lkely sell itself.
I looked for about 3 years before ordering mine in 99. It's a stout little truck, still tight as a tick 8 years later & still brings a smile to my face, every time I start it up & drive it!!!!
So drive it & give it a chance to sell itself, that test drive & info from this forum, will let you know if it's for you.
Keep us posted.
I know a few people with B-Series and Rangers and my sister has one. Theyre good little trucks. My sisters is fast. It has the 4.0. For a little 4X4, it is real fast. Theyre pretty dependable. Theyre safer than a car cause they have a real frame under them. Its not a civic. It has to be tough and better built cause its made to be that way.
I am not a hauler or puller, so putting a load on it would not be a problem....Oh, occasionaly I might haul something like a few pieces of lumber, but other then that, I would use the vehicle for getting from point a to point b. Incidentally the vehicle is not a four wheel drive and has a regular cab which is what I want.
It is snowing here in western Oklahoma this morning....so that curtails any plans to look into the vehicle today. However, like I have always said, you guys are a big help. This FTE room is the best reason I have for having a computer....Thanks so much for all the information and hellp....Nomadic
If it's a manual, the shifter will be on the floor, if it's auto, the shifter is on the steering colum.
The 3.0L Vulcan engine is a pushrod design, thats been around a looooong time & is very reliable.
Consider trying to contact the prvious owner & pump him for info & why he traded it in.
if you can't come by any previous owner/s info consder the following in checking this ride out.
The 4 & 5 speed OD auto trannies like to have their fluids & filter changed on time, so if it's the 4spd OD auto tranny, check the fluids condition.
In fact, check the condition of ALL the fluids, including the power steering & brake master cylinder fluids, serpitene belt & brake linings, as a major service period was 60K & as it's at 80+K miles & is close to another scheduled maintenance.
If it's a manual tranny, look underneath at the condition of the rubber plugs in the tranny case & make sure they aren't leaking & check the tranny fluids condition.
If it appears none of the fluids have been change on time, I'd do a careful test drive with a close ear for undue noises as Mudflap has suggested.
Turn the ignition key to ON, but don't crank the engine & make sure ALL the dash warning lights light up, especially the CEL (Check Engine Light) & ABS (Antilock Brake System) warning light, as many times folks will pull these lamps, trying to hide a problem.
Edit: Forgot, my upper & lower ball joint dust boots are shot at 60K/8 years, so be sure to check those too, cause if bad, you'll need the ball joints replaced.
If you suspect a engine or emission system problem, on the test drive, drop by your favorite autopars store, for a no cost computer trouble code scan & post any & ALL code numbers they find.
If all appears ok, then either have them do the 90K maintenance, or knock $500 off the trucks price, cause thats probably about what it'll cost if you have a Dealer do it, but if you do it, maybe $60-$80 depending on whether it's a manual or auto tranny.
As sfcwoodret suggested, if it needs tires, either have them do it, or knock off some more, for a good set of tires of your choice.
Sounds like this model truck is just about what you need, hope all works out ok, so keep us posted.
Just a bunch more things for pondering.
My 92 with the 3.0 auto consistantly gets 20-22 mpg. This is with a 42 mile a day round trip into Orlando in all kinds of traffic, every day becomes more stop & go....
Oh & it has 160,000 plus miles on it. As everyone says, they're a little light in the rear starting out on a wet road. You gotta have good tires.
Good luck !
BPF
