456 gears
Old Dec 14, 2007 | 10:48 AM
01redcrew's Avatar
01redcrew
456 gears
ive talked bout getting 456 gears and i had another question before i sat into buying them. Do these gears help with the fuel mileage in and around town. I do alot of 30-35mph driving and 40-45mph as well. Will these new gears improve my fuel mileage?
thanks
Old Dec 14, 2007 | 04:35 PM
Bob Jusnes's Avatar
Bob Jusnes
I have had at least 2 customers put 4.56 in their lowered F150s on stock size tires, with a great increase in performance, a small increase in city driving, and hardly any difference in highway driving. On tires as big as yours, I would do at least 4.56 gears. Keep in mind though it will be expensive since you are 4wd
Old Dec 14, 2007 | 05:15 PM
Dustin1690's Avatar
Dustin1690
I dont think it will increase gas mileage that much if at all remember you need to regear front and rear diffs
Old Dec 15, 2007 | 07:09 AM
WhëëlMå1's Avatar
WhëëlMå1
thanks
With tires of those size, a swap to 4.56s will turn the truck into a completely different beast! You will gain back the mechanical advantage lost when you moved up in tire size. This will translate to your truck not having to work as hard to spin 'em. As for gas mileage, it should be better than what you are getting now with the stock gearing and those heavy meats, but I doubt you will make it back to exactly the factory ratings.
Old Dec 15, 2007 | 10:37 AM
ech0sh4y's Avatar
ech0sh4y
Let us know how it goes and total cost i'm running 35's as well and would like to the same... just not sure on cost yet =\
Old Mar 17, 2008 | 11:41 PM
deisele75's Avatar
deisele75
Hey 01Redcrew,
I see you sig says 4.56 Gears. I guess thats means you went through with it. What are your thoughts and feelings on the upgrade?
Old Mar 18, 2008 | 12:04 AM
XolieX's Avatar
XolieX
wow4.56 gears, thats pretty steep! i was thinking more on the 4.10 side!
Old Mar 18, 2008 | 09:03 AM
WhëëlMå1's Avatar
WhëëlMå1
I have always found 4.10s are good for 33s, 4.30+ for 35s. He certainly could have used 4.10s, but the greater the mechanical advantage, the easier time the truck will have turning those heavy tires.
Old Mar 18, 2008 | 09:14 AM
scottie2hottie's Avatar
scottie2hottie
If he's doing mostly city driving I wouldn't shy from 4.56s, but you need to keep in mind that this is a permanant upgrade. Next time you wanna go 75 down the highway I'll bet you notice the difference a whole bunch, but that's not so much of a jump that you won't be able to.
Old Mar 18, 2008 | 10:06 AM
01redcrew's Avatar
01redcrew
sry i replyed so late. But the 456s was a big improvement the truck doesnt seems doggy anymore and i can now spen my 35s a lil more
Old Mar 18, 2008 | 10:37 AM
Field Scout's Avatar
Field Scout
I realize the diffs are larger than that of the H3 but a word of caution if going off road going from say 373 to 456 your teeth are thinner/weaker and youve gained torque/lowend power. When I had an H3 that comes standard 4.56 myself and others have gone through several diffs while off road all with only 220 lbs of torque from the little 5 cylinder versus what the big V8 puts out if your not carefull you could find yourself stranded.
just my .02 Steven
Old Mar 18, 2008 | 10:44 AM
01redcrew's Avatar
01redcrew
thanks for that info to but im not planning on taking my truck off road
Red69
Aug 30, 2014 01:02 PM
SCRebel
Nov 27, 2012 10:25 AM
benson az
2009 - 2014 F150
19
Oct 16, 2009 02:43 PM
BootHill
1978 - 1996 Big Bronco
Jan 13, 2005 08:55 PM
chaser
Feb 7, 2002 09:41 PM
