replacing brake switch
Old Dec 14, 2007 | 10:29 AM
bighunt34's Avatar
bighunt34
I need a diagram on changing out the brake switch for a 98 ranger. Can anyone point me in the right direction?
Old Dec 14, 2007 | 11:37 AM
87 XLT's Avatar
87 XLT
Should'nt be hard to figure this out, but if you need a manual a 20 buck Haynes will tell you how to do it.
BTW, if the brake lights are not working AND you cant shift out of park, the brake light switch probably is the problem.
Old Dec 15, 2007 | 10:31 AM
Hank85713's Avatar
Hank85713
the switch is easy look at the brake arm there should be the switch. Pop it off disconnect the connector and reverse the removal for install. no wiring to cut or change.
