Sponsored by: Real Truck
track bar or not?
Old Dec 14, 2007 | 09:12 AM
fordboy2's Avatar
fordboy2
track bar or not?
I just bought a skyjacker 2.5" coil spacer for my 2006 f350.(kit f52) I was wondering if I should do an adjustable track bar or a track bar bracket also. I also would like opinions on if I should do a dual steering stabalizer, for now I am just going to run the stock 20" tires I have until spring.
Old Dec 14, 2007 | 12:20 PM
riggz's Avatar
riggz
an adjustable track bar should be fine for only 2.5". Unless you are planning on doing some serious off roading, dual stabilizer's are a waste and will make it stiffer when turning.
Old Dec 14, 2007 | 01:12 PM
supeRobertduty's Avatar
supeRobertduty
I did the DR Adj trac bar and love it, I centered the front end perfect. I found that the front end was off (a little) to Driver side from the factory. I like the idea of making it straight and square not just close. If cost is not a issue this is the way to go.
