speakers in door
Old Dec 13, 2007 | 07:45 PM
rmalottwtes30's Avatar
rmalottwtes30
speakers in door
I did have the wires ran from the door to the stereo area but removed them due to being all chewed up..How can I get them back through the holes without having to tear apart the drivers side? it looks to be kind of hard getting it back in there...
Old Dec 13, 2007 | 07:48 PM
Mil1ion's Avatar
Mil1ion
You have to remove the door panel.
Old Dec 13, 2007 | 07:57 PM
rmalottwtes30
Dennis im talking about when you run it through the side of the cab down around where the vent is...
Old Dec 13, 2007 | 08:12 PM
Mil1ion's Avatar
Mil1ion
If you attach the speaker wire to some mechanics wire ... you can snake it through you may be able to grab it by reaching way up under the dash.
Old Dec 14, 2007 | 06:42 AM
paulsrx700's Avatar
paulsrx700
I get some rubber grommets and put them in the holes, that should keep the wiring from getting tore up, also you can buy the small plastic wiring wrapp to.
Old Dec 14, 2007 | 01:20 PM
Squam74's Avatar
Squam74
You're talking about and old Ford truck, you couldnt ask for anything easier to wire! Get up under there and just feed the dang wire through to the holes in the pillar and then into the hole in the door. Grommets would be a good idea. Definitely have to take of the door panels.
