Sponsored by: Real Truck
Vent switch revisited
Old Dec 12, 2007 | 09:56 PM
Snortwheeze's Avatar
Snortwheeze
New member, found site last nite. Seems to be some "gurus" here. 2000 1T crew 4x4. New wheel bearing assembly week ago, defrost blows all the time no matter what control is on. Thanxs to previous posts, found we didn't put vacuum line back on hub. Vent control works in 4wd, but intermittently. Did not have the problem before replacing bearing. On side note, have had problems getting out of 4Lo, doesn't seem to bother in 4Hi. Related? Every thing else seems to work. Week vacuum pump? Just a vacuum leak? How to tell?
Thanx in advance for the input.
Old Dec 12, 2007 | 10:36 PM
rbaker6336's Avatar
rbaker6336
you've got a vacuum leak somewhere
Old Dec 13, 2007 | 12:04 PM
FordTruckNoob's Avatar
FordTruckNoob
Did you replace the knuckle and hub seals when you replaced your bearing? Those need to be replaced any time they come apart.
