I am blowing a 20 amp fuse #22 in Distribution box under hood.
It is for: Fuel line Heater, Glowplug controller, and PCS relay coil.
Just started yesterday. It has eaten about 6 fuses, but finally will quit and start and run fine. I found a 30 amp in this spot, but the book shows it to be a 20 amp. I swapped the horn relay and PCS relay to see if that could be it, but won't be able to tell until morning.
Anybody else have this? I am afraid to take it to dealer $$$$$$$$$$$$.
