low oil pressure???
Old May 23, 2001 | 03:25 AM
steeringgear's Avatar
steeringgear
low oil pressure???
Hi, im new to this group and i own a '82 ford f150 with 300 inline six. I recently installed an oil pressure gauge and it when idle it only has 16 pounds of oil pressure. Is this normal? When i step on the accelerator it climbs up to around 35 pounds. What do you guys think? Thanks
Old May 23, 2001 | 09:17 AM
PAUL_2's Avatar
PAUL_2
low oil pressure???
The oil Psi should be 40 to 60 Psi @ 2000 rpms . Does it use a lot of oil ? Make any noise ?
Old May 23, 2001 | 12:02 PM
steeringgear
low oil pressure???
Hi again, I checked the oil pressure at 2000rpm's and its 42psi. the engine doenst make very much noise and it burns half a quart in 3000 miles.
Old May 23, 2001 | 07:35 PM
brown 4x4's Avatar
brown 4x4
low oil pressure???
[font size="1" color="#FF0000"]LAST EDITED ON 23-May-01 AT 08:37 PM (EST)[/font][p]That doesn't sound too bad. How many miles are on it? Mine (fairly new - 16K miles) stays right at 50 above idle and 25-30 at idle.
1986 F-150 4x4 300 I6 NP435
Old May 23, 2001 | 07:56 PM
steeringgear
low oil pressure???
The truck is on its second engine which is out of a 1977 f350 so im guessing it has around 100,000 miles on it. I did take the valve cocver off and noticed there is alot of sludge everwhere. Could the pickup screen be plugged and may also have damaged/worn the pump? Thanks guys.
Old May 24, 2001 | 05:32 PM
mudinford's Avatar
mudinford
low oil pressure???
