Another transmission question...
Old Dec 11, 2007 | 10:35 PM
turret_plug's Avatar
turret_plug
I may keep my C4 tranny but, it appears to be leaking from the tailshaft of the tranny....or......where the driveshaft connects to the back of the trans, (I am not too sure of the specific name)....anyway, Is this an easy fix, can I do it myself, or should it go into a shop? Next, the kickdown is not connected, I dont even have the cable or rod that goes to my carb for it, can I do that, or should I take it to a shop................?
Old Dec 11, 2007 | 11:48 PM
'85 SIX BANGER's Avatar
'85 SIX BANGER
If it's the slip yoke leaking, it's a pretty easy fix, just a press in seal I believe. As far as a kickdown it mught be vacuum, but I don't know for sure, It's been a long time since I played with a c4...
Old Dec 12, 2007 | 07:11 AM
turret_plug
it does have a vacuum modulator that is connected to it, and it is working fine, But when I bought my new carbeuretor i had to buy a ford "kickdown lever attachment", but my tranny shifts good..... except when I put her in reverse........kaaaaaa-chunk
