speedometer gears
Old Dec 11, 2007 | 01:43 PM
bigbubba87's Avatar
bigbubba87
speedometer gears
i have an 87 f250 with a c6 and the speedometer quit the gear on the end of the speedometer cable is stripped out. there is different teethed gears for it. how would i regear it if i want to run 35s it has the white gear now. thanks Justin
Old Dec 11, 2007 | 11:24 PM
mejonz's Avatar
mejonz
I had the same thing happen to me shortly after I got my truck.the gears come in different sizes and different colors when I called up the ford stealership they wanted to know what color then counted the teeth to make sure it was the right one The gear was pretty cheap I think less than ten bucks
Old Dec 12, 2007 | 07:23 AM
bigbubba87's Avatar
bigbubba87
ive replaced the gear once i was just wondering if you could get a different color gear to regear it for bigger tires?
Old Dec 12, 2007 | 03:01 PM
speedrdr's Avatar
speedrdr
i think the color is so they don't have to take off shoes to count the teeth. LOL. may be wrong about that, but dealer parts guy told me that all i had to do was count the number of teeth on what was running the speedo correctly with the stock tires and then put the oversize tires on and determine the amount you're off and lets say 15 percent off, then you need a gear with 15 percent more teeth, more or less....
speedrdr
Old Dec 12, 2007 | 03:29 PM
mejonz's Avatar
mejonz
here's a link that might help
www.bgsoflex.com/speedo1.html
I was also reading to slow down a speedometer add a tooth (approx 5 mph) to speed up a speedo subtract a tooth
Old Dec 15, 2007 | 08:29 AM
bigbubba87's Avatar
bigbubba87
ok thanks il figure it out its snowing here so im gona do much right now thanks for the info justin
