351 Modified?
Old Dec 11, 2007 | 12:26 PM
tylstruck's Avatar
tylstruck
351 Modified?
I always believed a 351M was a 351 Michigan. Is there such a thing as a factory 351 Modified? Modified in what way?
Last summer, I bought an old '75 half-ton 4x4 for chump change. I stripped it for parts. The truck was a true pitty, it was used as a snow plow. Rust holes everywhere and every panel was dented or weak. It had a 351 engine in it. One fellow bought the tailgate from the truck and looked around at its remains and was interested in a 351 engine, however as soon as he saw it, he said the engine is a 351 modified and wasn't iinterested in that.
I did ask him how he could tell, and how is it modified. No explaination was given. I'm still puzzled by this modified nametag. I know the 351 could be built as a 400 and vice-versa. Is that what he meant?
Tyl
Old Dec 11, 2007 | 01:01 PM
Jodell's Avatar
Jodell
tylstruck,
The meaning of the "M" after the 351 seems to be up for debate, but many use modified since Ford destroked the 400 engine to make the 351M. The block seems to have been cast in the Cleveland, Michigan, and Dearborn factories. Since Ford made three different 351 engines they all have a letter designation after them; M, C, or W.
Here is a link to a great site for information on the 351M/400 engines.
http://home.earthlink.net/~bubbaf250/index.html
Hope this helps,
Jeff
Old Dec 11, 2007 | 01:56 PM
fmc400's Avatar
fmc400
MSEE
"Modified" is just another common interpretation of the M behind 351. Modified is what I hear the most, but I also hear a lot of people say Michigan, like you do. I've even heard "Midland." I think Modified is the most common one because the 351M is a modified 400 in that it uses a different pistons and a different crank to destroke the same block to 351 cubic inches. Either way, you guys were looking at the same motor.
Old Dec 15, 2007 | 03:19 AM
CE-f250's Avatar
CE-f250
According to the book "Ford Performance", all 335 series engines were built at Ford's No. 2 engine plant in Cleveland. After the 351C was discontinued in 1973 the plant in Windsor, Ontario couldn't build enough engines to keep up with demand. So Ford took the 400 and de-stroked it down to 3.5 inches, (the 400 has a 4 inch stroke) and ended up with the 351 modified. And unless someone pulled the original engine and put in a 351M, your truck has an FE engine, either a 360 or 390. The first 400 didn't come from the factory until late in the 1976 model year. The first 351M didn't show up until 1978. An easy way to identify an FE engine is to look at one of the cylinder banks. If the front two spark plugs point to the rear and the rear two plugs point forward it is an FE. If they all point in the same direction it may well be a 351M or a 400.
Old Dec 15, 2007 | 03:33 AM
fmc400's Avatar
fmc400
MSEE
Those dates are wrong. The 351C was around throuh 1974. The 351M came out in 1975. The 400 started in 1971. Both the 351M and 400 started showing up in trucks in 1977 (D7TE block). Many sources out there to back all that up. I agree though, the engine isn't original because a '75 wouldn't have a 351M yet.
Old Dec 15, 2007 | 06:03 AM
idfergusson's Avatar
idfergusson
My Ford Racing catalog refers to the 351M as a 351 modified so it would seem that Ford refers to them that way.
Old Dec 15, 2007 | 09:10 AM
father/son's Avatar
father/son
hi fmc400, paul here,
i am one of those guys who call that block a midland, i also know that the debate is endless and when i first joined i saw a couple of rules on the site about the fact the site was tired of the debate so i did not get into it, but you know what, i have never been afraid to admit it when i am WRONG, just for the record, it is becoming apparent to me that it is a modified, not a midland, i like to try to be correct, and i appreciate your post and your info, i really do thanks, can paul say modified (grin) later,me md
Old Dec 15, 2007 | 10:53 AM
73XAFalcon's Avatar
73XAFalcon
I strongly dislike that book. It's full of several myths and plain old BS. One being that first statement, the 400's were being cast at MCC before 1973.
Old Dec 15, 2007 | 04:31 PM
tylstruck's Avatar
tylstruck
That can't be right that Ford managed to destroke a 360/390 block to a 351 modified. If so, only one thing can prove that, I'll copy the block's id number and decode it to a ? I don't have the engine, it is at a friend's salvage yard which I will go to and find the block's number. The truck is burried in snow with no fenders or inner fenders attached, so it'll be easy for me to check. Where would the id number be on the block? Does anyone know the block id for a 360/390?
Tyl
Old Dec 15, 2007 | 07:11 PM
fmc400's Avatar
fmc400
MSEE
Tyl
Hi Tyl - The FE block was not destroked - it was the 400 that was destroked to form the 351M. Hence, they both use the same block which is generally referred to as an M-block. A quick way to tell is to get a look at where the upper radiator hoses go. 351M and 400s are unique in that they have a dry intake manifold. The upper radiator hose will go straight down into the block. This means there is no coolant in the intake (hence the term "dry"). If the radiator hose goes to the intake, that eliminates the possibility of a 351M, and then it could be a 360/390, or even a Windsor. The block numbers are probably underneath tucked behind the starter and won't be easy to see, especially if you've got a lot of snow. I know I wouldn't want to be lying under the truck in that weather
prerunnerswag98
27
Nov 11, 2011 03:36 PM
scotttruck
Jan 12, 2005 05:35 PM
FordRacing2
15
Aug 12, 2003 09:39 PM
DogFuzz
Aug 3, 2003 10:07 PM
canadianfordman
Jan 22, 2001 12:40 AM
