Sponsored by: Auxito
Wicked toe-in help
Old Dec 11, 2007 | 09:40 AM
hillbillymagic's Avatar
hillbillymagic
Wicked toe-in help
I have a lifted 97 F150 that is have some wicked toe-in issues. When I put it into 4wd the front passenger tire turns in. Also when I back up my front tires point at each other. Does anybody have any ides on what to look at?
Old Dec 11, 2007 | 09:41 AM
hillbillymagic
Also it drives fine going forward in 2wd.
Old Dec 11, 2007 | 02:51 PM
tim.moman's Avatar
tim.moman
Sounds very worn out. Ball joints are known to be bad with mileage and are almost a given to need replaced.
Since it is changing when going to 4wd, you can watch for movement. Check your idler arm first. It is easy to see if it is allowing the drag link to move up and down. A-arm bushing are next and will be similarly easy to see movement. The lower arms would be a final suspect. Nothing left in the front suspension after that. lol
Old Dec 11, 2007 | 03:00 PM
Bobby82490's Avatar
Bobby82490
Wow definetly dont drive it anymore than you have to. The front end must be very worn out for it to do that.
Old Dec 11, 2007 | 03:05 PM
hillbillymagic
Thats what I'm thinking but there is no vibration at all while driving. Something could just be loose. Defenitly scare either way.
Old Dec 11, 2007 | 03:19 PM
tim.moman's Avatar
tim.moman
Good point not to drive it.
That suspension will practically fall off before it will act poorly.
jhobbs26
May 30, 2013 03:41 AM
BolderKeith
Apr 20, 2006 06:02 PM
gml
Apr 28, 2005 01:40 PM
flyboyutah
Garage & Workshop
47
Oct 14, 2003 03:32 AM
