Rocker arms
Old Dec 11, 2007 | 09:04 AM
codyingersoll123's Avatar
codyingersoll123
Rocker arms
Is the increase in power for 1.7 rocker arms really worth the money? Does anyone have any suggestions on what ones to buy? Also do you have to replace the factory springs or anything to put these in or is it pretty much just a swap the old stock ones out for the new ones?
Old Dec 11, 2007 | 08:27 PM
baddad457's Avatar
baddad457
Ford found a 15 hp increase in using full roller 1.7's over the stock 1.6 stamped steel rockers in their development fo the 93 Cobra 5.0. Some is due to the increased lift, some from the stabilized ratios and most from the friction reduction in the roller trunion. No other mods needed for pedestal full roller 1.7's, just change the pushrods when you do the rockers (if your motor's a roller cam and has about 100K miles or more on the pushrods)
Old Dec 12, 2007 | 07:11 AM
codyingersoll123
ya but do you really think its worth the money? or is there something better powerwise for about the same money?
Old Dec 12, 2007 | 07:44 AM
Conanski's Avatar
Conanski
What motor we talking here?
Old Dec 12, 2007 | 08:34 AM
codyingersoll123
its a 95 F150 with a FI 302
Old Dec 12, 2007 | 03:04 PM
Conanski's Avatar
Conanski
1.7 rockers provide a pretty good boost to total valve lift pushing it from 0.422/0.448 to 0.447/0.476, but the duration remains much the same so the powerband doesn't change a lot. Most people with 1.7 RR's report a nice boost at max rpm but not as much elsewhere. Combined with longtube headers they are probably the best upgrades for the 302 in the relatively easy to add category.
Old Dec 12, 2007 | 08:47 PM
baddad457's Avatar
baddad457
Definately worth the money. Even if you buy new. You can still find used sets for $100 or so. I've bought two used sets for $100-125. One set had 100K miles on them according to the seller. I've had this same set of rockers on three different engines in the past 5 years and they show no signs of giving up. Another benefit is lower oil temps, your oil stays cleaner & cooler longer. In my opinion, buying full roller rockers is a damn site better buy than any of the dizens of "cold air" kits that are so popular now.
rdweathers
19
Nov 15, 2016 03:59 PM
Kyle Wood
Nov 6, 2016 04:11 PM
400inatruck
17
Jul 27, 2012 08:04 PM
fordpride
Jan 10, 2010 06:38 PM
Motorcraftsman
Oct 8, 2000 04:27 PM
