Missouri Chapter Join Chapter , Leader:77&79F250
Am I a moron?
Old Dec 20, 2007 | 12:20 AM
  #31
97 Mountain Man's Avatar
97 Mountain Man
My 92 will break the tires loose if there is one drop of rain on the pavement. I swear I can out back pedal John Force it's so bad. It should really be fun when I put the 3.73's in it. I will be adding a traction lock diff though.
Old Dec 20, 2007 | 08:54 PM
  #32
Level2's Avatar
Level2
If you are going to go ahead and put in a LSD and if you don't mind spending a few extra bucks, go with the Auburn differential. I put an Auburn Pro LSD in my 85 GT and it works great. Still a clutch driven unit but it has cone shaped clutches. Or you can use a good gear driven unit from Detroit, Lock-Right, Eaton, or Torsen. I like the Torsen 8.8 31 spline in the rear of my Ranger....its pretty tough. The 8.8 in my Stang came from a Ranger with 3.73s and Traction-lok.
