Climate Control lights out
Old Dec 11, 2007 | 02:08 AM
grip1968's Avatar
grip1968
My 98 XLT 4.6 EXP climate control unit below the radio the lights are out.
do the blubs need to be replace or is it a short in a wire???
Old Dec 11, 2007 | 02:09 PM
Ogio's Avatar
Ogio
Does it work? It's just the lights are out?
Old Dec 11, 2007 | 04:23 PM
grip1968's Avatar
grip1968
yes the climate control work's fine it's just the lights on all the *****
are out. I check the fuses everything is ok. Im thinking it might by a
loose wire or something?
Old Dec 12, 2007 | 08:45 AM
grip1968's Avatar
grip1968
OK, I hope someone can help with this, I did a lil troubleshooting
I pulled the bezel off the center console and i notice 4 screws around
the climate control do i need to unscrew those to pull it out to see whats
wrong. Also I notice that the lights came on for a lil while then they went
back out so I think it might be a bad wire or something. If any every had
this problem plz give me some info, I called the dealer they want 110.00
dollars just to look at it, NO WAY....
Old Dec 12, 2007 | 10:09 AM
fitzy67's Avatar
fitzy67
blown bulbs???
the light bulb is located directley behind the bezzel that contains the switches. very easy to do. I f the bulbs are black they are burnt. the first part is to take off the surrounding cosmetic bezzel just by pulling, no screws. then take off the four screws. no need to disconnect wires just look fo rthe blown bulbs and twist them out of the socket.
