T-Shirt samples/ideas for Gatlinburg Excursion 2008
#61
on
Originally Posted by guiri
Colors, logos, graphics, band aids, you name it. Right now, I have the time since I don't work and even if I get a job, I should be able to do it. It doesn't take me long. HOWEVER, I need to find the right printer AND someone that can read my Corel Draw files which is what I work in and not ALL printers will so feel free to help me on that.
#62
All these power plants WON'T likely fit...although some are obviously from non-Sooper Dooties but older 3/4 toners and up...
Modern Gassers: 5.4L (330) 6.8L (415)
Older Gassers: 5.9L (360), 6.4L (390), 7.5L (460)
REALLY Old Gassers: (1958-1981) 6.5L (401), 7.8L (477), 8.7L (534)
Smokers: 6.0L, 6.4L 7.3L
Oh yeah nick...notice the 6.0L and 7.3L are on the list!
#64
#66
#67
#70
on
Tex, are you a printer?
I can export to just about any format but if I do, you won't be able to break elements apart and move them around if you need to but yeah, I can probably separate and all that stuff.
Tex, I think you might have a fight on your hands. Them Diesel boys get a little feisty
#71
#72
#73
Tex, it has nothing to do with different products but they are two different file formats and they have never been compatible, on any program.
Draw is a VECTOR format and the others are bitmap. Ie, photoshop and PICTURES are usually bitmap and simpler graphcis like the shirts which are also much cleaner and sharper are/can be/should be vector format.
Flash on the web is a vector format and that's how it all started. Flash had the ability to give you VERY small files/fast loading while still giving you a lot so to speak. Same with Corel. The tshirt files are maybe a few hundred kb in size but if they were photoshop they would be 5-10 megs. Huge difference.
You simply cannot manipulate one of the files with the other program, that's why.
