Cold Starting Problem
Old Dec 10, 2007 | 10:38 PM
newportman's Avatar
newportman
Is There Anything Besides Glow Plugs That Can Cause Cold Starting Problems? How Do You Check Glow Plugs? Does My 1996 F-250 P.s. Have Any Type Of Fuel Heater? Thanks For Any And All Help.
Old Dec 11, 2007 | 12:40 AM
HT32BSX115's Avatar
HT32BSX115
Howdy,
If the timing is retarded too far (only a few degrees) it absolutely won't start. And it it's only retarded a little, but the automatic timing advance is not working, it won't start either.
Old Dec 11, 2007 | 11:56 PM
newportman's Avatar
newportman
no help here!!!!
very dissapointed in the amount of non help on this site. I got one reply to a cold starting problem with my 1996 F-250 powerstroke. I replaced the glow plugs 2 yrs. and 15,000 miles ago,could they be bad already? Any help this time? thanks.
Old Dec 12, 2007 | 05:58 AM
scatgo's Avatar
scatgo
Link
The link below might help.
https://www.ford-trucks.com/forums/4...ke-thread.html
Old Dec 12, 2007 | 09:14 AM
fordfish's Avatar
fordfish
plug it in, on a timer, to start about 3 hrs before you are ready to leave.
Old Dec 12, 2007 | 12:12 PM
rollerstud98's Avatar
rollerstud98
maybe wait a little longer and people might help you? making posts like this makes me definitely not want to help you out, also you could check the forums specific to your model year and make the thread in there, might get better luck then
Old Dec 12, 2007 | 02:50 PM
rbaker6336's Avatar
rbaker6336
might want to check glowplug relay,would be next step if glowplugs are good
Old Dec 12, 2007 | 06:59 PM
Maxium4x4's Avatar
Maxium4x4
Moved you from General Diesel.
Old Dec 12, 2007 | 08:40 PM
ftowelding's Avatar
ftowelding
I am having similar problems as you are. I have put in new glow plugs, relay, temp sender, batteries, and still no cold start. I am currently checking on some other ideas that a IH mechanic buddy told me about. Check in with me in a couple of days and I may be able to help.
Old Dec 12, 2007 | 11:13 PM
newportman's Avatar
newportman
Thanks For The Help Guys,when It Gets Cold Again I Will Try And Check The Relay. I Am In N.c. And Its Getting Almost To 80 Degrees Here Now,no Starting Problems.
Old Dec 13, 2007 | 04:46 AM
Cuda_jim's Avatar
Cuda_jim
Lets see, you waited an 1.5 hours between posts and......posted in the wrong forum and you are disappointed. Then you must not have read what others posted here, if you did then you missed an opportunity to apologize after rollerstud98 politely pointed out your impatience/error. BTW: This is the best website for getting free information on your PSD....period! OK, I'm done
Welcome to FTE.
Old Dec 13, 2007 | 05:14 AM
MADVAN's Avatar
MADVAN
Bill
Old Dec 13, 2007 | 01:02 PM
newportman's Avatar
newportman
Sorry If I Ruffeled Some Feathers With My Inpatience, It Was The Second Post On This Problem With No Responce First Time,i Am New Here So Im Sorry It Was In Wrong Forum. As For Cuda Jim ,practice Your Math And Calender Reading Skills,it Was 25hrs,18mins. Between Post.thanks
Old Dec 13, 2007 | 01:06 PM
Action4478's Avatar
Action4478
Oh, Oh....
Old Dec 13, 2007 | 04:02 PM
Cuda_jim's Avatar
Cuda_jim
You're right! I need to practice my math and reading skills....and I will, when I get enough time away from here helping others (and getting help too). I really do apopolgize and need to slow down while reading these posts.....during breakfast this morning, before I go to work (the one I get paid for) and during my lunch period and any free time after work too.
You could ask for your money back, waiting 25 hours, 18 minutes is way too long of a wait for the advice you need. OR, Perhaps you should have fixed last month...the first time you posted the same symptoms https://www.ford-trucks.com/forums/6...-starting.html . Maybe I'll follow your lead and slow down, do nothing until it's an emergency, then expect others to drop everything just to help you out.
The SEARCH feature would have givien you all the info you need. There are many, many posts on this subject.
