Torque Specs Rods/Mains/Head????
Old Jun 20, 2001 | 01:09 PM
Fracster's Avatar
Fracster
I need the tourque specs for the rod bearings/ main bearings/ and head for the 300 I6. I just put a new set of rings in and replaced number 5 piston, re-installing everything and hope someone would take a peek in their manual for these specs....This truck is 1985 F150 4X4 Thanks Brett
Tampa, FL
1985 F150
Old Jun 20, 2001 | 04:59 PM
StrangeRanger's Avatar
StrangeRanger
For a 96 the specs are:
Mains: 60-64 ft-lbs.
Rods: 40-45
Head: tightening sequence (bolts numbered fron front of engine #1 to rear #7)
L4
R4
R3
L5
L3
R5
R2
L6
L2
R6
R1
L7
L1
R7
Tighten in sequence to 45-55 ft-lb. then RE-TIGTHEN EACH BOLT IN SEQUENCE AN ADDITIONAL 80-100 DEGREES. No final torque spec is given????
I'm not at all comfortable with this, but it's straight out of the Ford shop manual.
Old Jun 20, 2001 | 08:43 PM
Fracster's Avatar
Fracster
Thanks a bunch, this will save me a lot of time..... Maybe i can return the favor in the future....
Thanks Brett
Tampa, Fl
Old Jun 21, 2001 | 05:49 PM
traildawg's Avatar
traildawg
palace55
Apr 28, 2010 09:59 PM
eurosurplus
Jan 14, 2010 12:02 PM
78 Ranger
Jan 13, 2006 04:41 AM
83f100ss
Jan 24, 2004 10:54 PM
kburts
Jun 8, 2001 03:46 PM
