truck won't start!!!
234,000 miles
have had no major problems in several years.
parked yesterday afternoon at a store: truck would not start. turned over easily. do not think it’s the battery, starter, etc...
AAA towed it home. when it got home - it started!!! parked it until this morning.
Started up this morning. drove 1/4 mile. at idle, it stalled and I could not restart. again - engine turned over easily.
Had AAA tow it to Ford Dealer this morning. At 4 pm, I call them since I have not heard anything yet: they could not diagnose the problem because it started EVERY time they tried it. no codes, no alarms, etc. I pick the truck up and...
I drive it home. Stop at a store. It does not start AGAIN! And again, the engine turns over easily, but does not start.
all three times, I checked the fuel pump reset and it is okay (it has not tripped). I was thinking fuel pump or fuel filter problem...
what am I missing? What can I tell the Ford dealer to check in the morning? Any thought from anyone would be greatly appreciated!
Thanks in advance!
-red5
Update:
Drove it home last night. No problems. Parked at the food store, came out 20 minutes later and it would not start.
Left it overnight. Walked home and walked back to it in the morning (about 9 hours later). Was waiting for AAA to arrive to tow it again – but I tried it and it started right up.
Drove it to the dealer about 26 miles away on my way to work and it would not restart there.
One thing the Dealer tech noted as I was checking in and they tried to check the mileage: the odometer has no numerical readout, but a series of dashes in place of the miles. In others words, there were no miles, just a dashed line across the odometer.
Does that indicate anything to anyone?
Thanks again!!
-red5
12-15-07 update:
On Tuesday, Dealer found s short in the instrument cluster causing the problem. Cluster needed to be replaced, total cost: Approx $650.00.
Wed the part arrived from Ford. Thurs and Fri, they could not get new cluster to talk to the PCM (what I call, in layman terms for me, the “truck computer”…).
Friday: still not repaired. Now they have found the PCM is bad; that is why the new Instrument Cluster and PCM could not communicate. New PCM on order. Won’t know anything until Monday.
New total cost: approx $1200.00 !! !! !!
Someone help me: does this all sound reasonable (the root cause of the truck not starting, even tho it turned over okay, the cost for these items/repairs and the time it took to trouble shoot)?
What if this doesn’t solve the problem?
Should I expect the cluster and PCM to go bad after only 8 years? Or am I asking too much?
Thanks again!!
-red5
