Plug Wire Recommendations
Old Jun 17, 2001 | 12:51 PM
traildawg's Avatar
traildawg
I know there's alot of you out there running an MSD ignition system, and I'm wondering which brand plug wires you're all using. I know the MSD ignition requires the use of non-solid core wires, and since no matter where I go they need to order them I might as well get everyone's feedback.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.ProjectTrailDawg.com
Old Jun 26, 2001 | 11:59 PM
steakman_usaf's Avatar
steakman_usaf
Well call me retarded, but I'm a big believer in brand matching. If you've got an MSD ignition box, I say go with MSD everything. Anything will work, but if you keep it the same brand there might be a better chance that they will work better together.
Plus it looks better than having red MSD accesories, mixed with blue Jacobs accesories. It just looks funky... :- )
Chris
1982 F100 Flareside
Blue and Silver
31x10.5 BFGoodrich A/T K/O's
300 I-6 SROD 4speed 2:75 9" Rearend
MSD6AL, MSD 8.5mm S/C Wires
MSD Blaster 2F Coil
Runs on AvGas 100LL
215,000 Original Miles
Old Jun 27, 2001 | 07:47 AM
82F100SWB's Avatar
82F100SWB
I'm running a set of 1981 Duraspark II wires, they are older than the truck, and aren't the best, but they are better than the crap that was on my truck... I'm planning on getting a MSD 6 Off-Road and whatever wires have the lowest resistance and are cheap....
Evan MacDonald
82 F100 FlareSide 2wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
3.55 Geared ARB'd 9"
31x10.50/15 Cooper Discoverer LT's
Old Jun 27, 2001 | 05:01 PM
Eddie's Avatar
Eddie
Motorsport 8.8 wires for 460. V-8 volume pricing cheaper than an aftermarket set for a six; six out of the eight fit just fine. Who cares if they're marketed for a V-8?
Eddie
Old Jun 28, 2001 | 02:24 PM
82F100SWB's Avatar
82F100SWB
