Sponsored by: Real Truck
SD Ball Joint Replacement
Old Dec 12, 2007 | 02:21 PM
Racerguy's Avatar
Racerguy
https://www.ford-trucks.com/forums/3...ll-joints.html has a couple pictures of the Ford driver.
Old Dec 12, 2007 | 03:48 PM
FireGT's Avatar
FireGT
Jim59,
check out the link I posted just before your post.
It has a picture and the OTC number.
ken
Old Dec 14, 2007 | 09:59 AM
Jim59's Avatar
Jim59
RacerGuy .... so having the Ford - OTC tool is important to have?
I guess not to install the seal onto the axle, because you can tell when the seal bottoms out. But, for when you use the tool to install the axle into the knuckle? The length of the tool is important?
Last summer when I did one side of the truck, I thought it went so smoothly with the tool I made out of galvanized pipe from the instructions someone gave in your ball joint replacement thread?
I'm doing the ball joints on the other side over Christmas ... should I buy the OTC tool?
(BTW, I've sent many people to the link for your step by step ball joint guide .... it has saved a lot of people, a lot of money. Thanks. [I hope I have not been mis-guiding people telling them that I use the homemade pipe tool without a probelm])
FireGT ..... thanks for the link for the tool, I may be getting one.
Old Dec 14, 2007 | 10:10 AM
99f350sd's Avatar
99f350sd
I wouldn't think the OTC tool is necessary But it wouldn't hurt.
Old Dec 14, 2007 | 01:16 PM
dagren99's Avatar
dagren99
Axle Seals
At lunch today I had a chat w/ one of my Ford Truck Mechanic Friends I mentioned earlier. I said: "hey how did you mess up the seals you installed even though you had "ford's" special tool."
He came back with: I've installed 100's of these seals and probably messed up 6-7 of them in the last 2-3 years. Its not really a big deal. The ones I messed up were usually because either I got it started crooked or, the axle shaft had something wrong with it I failed to catch. Like gouges or grooves - these damaged the seal enough that the ESOF wouldn't work. As to using a homemade tool - just be careful on how far you drive the seal in. Too far and you'll have axle end play which would be bad - this would lessen how much hub-spline contact you'll have when engaged in 4X4 and could cause an issue with the diff as well. Not deep enough and the surface (face) of the seal will get worn by the hub when 4X4 is not engaged. (freewheeling) Not a huge deal but it could lead to a seal failure down the road which would let water/dust into the hub trashing the bearings. It would be best to mark or otherwise measure how deep to drive the seal in so it gets installed @ the right depth.
I asked another question: Why so many seals? Seems like a lot even for a dealership in that short amount of time.
He came back with: We have a lot of fleet operators who don't really maintain these trucks as good as they should. I'd say about 1/2 were for hub failures which ate up the axle leading to a replacement. Most of the rest were balljoints. A handful were because the ESOF failed - hubs wouldn't hold a vacuum despite replacing the o-rings, etc. Just a few were for axle leaks - diff lube leaking out the end.
Very interesting conversation w/ someone who works on this stuff for a living. He is the top Service guy for the SD's that this dealer sells. Couple of awards, ASE Cert etc, etc. Bottom line from him - take your time, do it right, check twice - do it once and everything will be just fine.
DG
Old Dec 14, 2007 | 06:20 PM
99f350sd's Avatar
99f350sd
I just install the seal on the axle and install the axle by hand into the knuckle. Then install the bearing and it pushes the seal in where it has to be.
Dick
njfirefighter15
Aug 27, 2015 09:39 PM
tls25rs
Jul 11, 2015 07:38 PM
kc2006
Nov 28, 2012 08:35 AM
fordff
Mar 13, 2010 08:49 AM
thedaddycat
Dec 2, 2007 01:12 AM
