460 identification help needed...
Old Dec 9, 2007 | 02:08 PM
nofortunateson's Avatar
nofortunateson
Is a 460 engine out of an early '70's F700 the same block as a passenger car or LT? Would the block be a 4 bolt main block? Any help with identifying/ casting numbers etc greatly appreciated. Casting number for a 4 bolt main block would be great. Thanks.
Old Dec 9, 2007 | 02:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original, no 460 was ever installed in a F700.
1965/78 F600 and larger trucks ~ FT engines: 330; 330 H/D; 361; 391.
D1VE-6015-AB: Bare block casting number for 429/460.
Cast in 1971. 429 block used 1971/74 passenger cars / 460 block used 1973 thru midyear 1979 on F100/350's and thru 1978 on passenger cars.
Old Dec 9, 2007 | 05:39 PM
nofortunateson
Thank-you for the info.
I aprreciate you taking the time to reply.
Old Dec 9, 2007 | 10:36 PM
AerostarDad's Avatar
AerostarDad
You might find that motor is a 370....the first generation of "385 series" engines. They were mostly an industrial/heavy-duty application.
Old Dec 10, 2007 | 11:50 AM
monsterbaby's Avatar
monsterbaby
except those didn't come out until 1979 so if it's in a early 70s F700 it's not original.
Old Dec 10, 2007 | 04:27 PM
Mil1ion's Avatar
Mil1ion
So go ahead and post the casting numbers off those engine parts so we know what it is.
Block/Heads/Intake
