Sponsored by: Real Truck
351 vs 460
Old Dec 9, 2007 | 01:29 PM
almost_nick's Avatar
almost_nick
351 vs 460
I was wondering if a 351 would get better gas milage than a 450 pulling a 8 inch lift and 38 inch tires??? would would be the gas milage at each??
thanks
nick
Old Dec 9, 2007 | 01:33 PM
1EVILCREWCAB's Avatar
1EVILCREWCAB
which 351, what gearing , what trans , what axles, all make a difference
rbaker6336's Avatar
rbaker6336
depending on gears the 460 might get the best
Old Dec 9, 2007 | 09:00 PM
almost_nick
im not sure what gears, but just say they both have the same stock gears
Old Dec 9, 2007 | 09:04 PM
rbaker6336's Avatar
rbaker6336
if you were running a 3.55 gear the 460 would probably get better milage
Old Dec 9, 2007 | 09:57 PM
UP_There's Avatar
UP_There
be prepared to get around 8mpg for either. 351 will have to work very hard to move those tires.....and the 460 will do a better job of it, but is a thirsty motor to begin with. What about a Diesel or V10? Changing gearing could help......but then the money you gain in mileage is already sunk into the gear changeout!
Old Dec 9, 2007 | 11:30 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Go with the 460, it's just all around better. Especially if it's one of those 351-M's. Those are just bad, the windsor aint a bad motor, but sounds a little weak for your application.
Think of it this way, if you lift ur truck 8 inches, you will most likely get better fuel economy hanging out the window just dumping fuel out of a gas can... if you are going to be broke, do it the right way
Old Dec 10, 2007 | 12:06 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
38" tires and 3.55 gears? Both engine's will feel like 4-bangers with that combo. Get some gears first! 4.88's should work wonders.
Old Dec 10, 2007 | 12:58 AM
wlihntr's Avatar
wlihntr
yea... i had a '95 bronco with 32" tires a 3 inch lift, 3.55 grears and the 351 and that thing was an absolute PIG!!! there where times while towing my boat it couldnt get out of second gear in a strong head wind
Old Dec 10, 2007 | 07:26 AM
rbaker6336's Avatar
rbaker6336
there was nothing wrong with the 351-M engines other than being a little thirsty
I still have one I bought new in '79 with over 250k miles pulling an 8k lb load on its back daily
Old Dec 15, 2007 | 12:50 AM
oltrucker's Avatar
oltrucker
my 77 250 4wd 8 ft narrow bed that i got new had a 351 m. it was locky to get 8 mpg, the 460 got 14!,,,i changed the late cam timing gears to the erly ones. its worth 25 hp and e z to do before you intal it. the only problem, you will tear up te transfer case blowing off the little chevy 350 trucks,,hehe. find a 350 trans & transfer case. a 77 or earlieris best. just got through it. the 460 is a real torque monster. you may have to rotate the case down to reduse the front shaft angle.
