Disc Brake Conversion
Old Dec 9, 2007 | 06:33 AM
tlb's Avatar
tlb
I recently bought a front disc brake conversion kit supplied by CPP. I will be running front disc's and rear drums. The kit includes the booster, master cylinder, combination valve etc. The prop valve is not adjustable. My brother in law who has been a mechanic all his woking career said i should have an adjustable prop valve. I went on CPP web site and read through their trouble shooting guide and according to them the adjustable prop valve is not DOT approved and is for racing applications only.
I am not expecting any problems with the kit i bought but if anyone has any comments or issues they had to deal with please let me know. Any help would be greatly appreciated.
Thanks
Terry
Old Dec 9, 2007 | 08:42 AM
AXracer's Avatar
AXracer
I wouldn't expect a problem, but you can buy an adjustable pressure valve you plumb into the line after the PV to the brake that is locking up prematurely if needed. You can also balance the brakes with different compound linings and even changing the width of the rear brakes. Unless heavily loaded the rear brakes on a pickup are going to be doing very little work.
Old Dec 9, 2007 | 10:28 AM
ghall's Avatar
ghall
used a complete kit on a 56...
i added residual valves after initial install... thought it was necessary because of long pedal travel.
seemed to slightly help.
it stops great though.
