Hi all
I am new to this forum and don't speak truck so please excuse my ignorace
My boyfriend has an older F-150 I think maybe 1990 and he's plugs it in at nights when it's cold. We live in DC and it gets cold here. COld enough that when he forgets to plug his truck in one night it won't start the next day.
Well he's getting ready to move into an apt building where he will not have anywhere to plug his truck in. What are his options? Is there some sort of portable something that he can get???
If he knows the watts used, he can get a small gas powered generator, honda makes a nice quiet one. Don't know where he would put it so it would dissapear though.
I'm with the others on this. The '90 in my sig always started in the cold here in Indiana. This generally includes a few nights a year that got as low as -25ºF with -40ºF wind chill. Like they said, I'd look into the alternator, battery, starter and oil weight. I've noticed that when batteries go south in the winter (ha ha), they tend to die slowly--a few slow starts before they don't work. When they die in the heat of the summer, they seem to work fine right up until they croak--they'll start fine in the morning, and leave you stranded when you go to leave work.
Yep its been 30- here for days . Only really need heater if a diesel. Have him check codes www.fordinjection.com will tell him how. If it cranks but wont start.
Does it not crank or not start? Let us know and get back
That and a good tune up will not only allow it to start when it's cold out, a equally benefit is it will get better gas mileage.
Using the block heater is just masking underlaying problems. It doesn't get that cold in DC, cold yea but no where near cold enough to stop a properly maintained truck from starting in temps down to -20 or -30 or more bellow zero.
(Edit, that would be a truck with a gasoline engine)
thanks for all the great info...
I guess I should have mentioned that it's a diesel truck. Does that make a difference as far as it starting up in the cold? I know compared to some of the places you guys are from it doesn't that cold here (ps, I'm from California! so dc gets pretty frigid for me ) but all i know is that he has to plug it in or else it won't start. And I know he takes good care of it...
where can we find a generator? Could he put it in the bed and run an extension cord from the grill to the back?
If it's a diesel, you need to make sure that the fuel has an anti-gel additive in it (some stations add it, some don't). You also need to make sure that your glow plug system is working. On a cold day, you'll have to turn the key on and wait for the "Wait to Start" light to go out before cranking. You shouldn't have to press on the accelerator, either.
Jason
Jason,
Are you saying that with the anti gel addictive it won't need to be plugged in?
neg
<i>I should have mentioned that it's a diesel</i>
Yea that was a small piece of "needed" of info!
But if it has a "working" glow plug in each cylinder and the injector pump and injectors are in good shape it should start just fine in very cold weather without any problem.
I gotta say I doubt people living at a apartment complex are not going to go for a genarator running in the parking lot all night. Regardless of how "quiet" it is.
It sounds like he isnt waiting for the wait to start light to go off, meening he is cranking on cold cylinders. Im not gunna get technical about it because no offence you dont really seem to know what your talking about here. so here is basically the general explanation of what is happening.
when that light is on the engine is warming itself up before you it can start, if he is trying to start the engine while the light is on not only will he damage parts, but it will take many trys to start the engine. He should turn the key only long enough to see the "wait to start" light come on, and then not turn the key any further until the light is off.
And these guys are right, you really shouldnt be needing a block heater for the kind of temps your in. Teach him how to properly use his truck.
