Rear End
Dec 8, 2007 | 11:39 PM
Rear End
How do I figure out what rear end I have in my truck?
thanks guys
Dec 8, 2007 | 11:51 PM
Look on ur drivers door, their are a bunch of codes. Post them up on FTE and ppl will tell u what kind u have
Dec 8, 2007 | 11:57 PM
Dec 9, 2007 | 12:55 AM
no problem, post ur code up once u get it
Dec 9, 2007 | 01:44 AM
Quote:
Don't you wish you had one of these?
Dec 9, 2007 | 01:57 AM
Second from the left - white is all right.
Dec 9, 2007 | 03:03 PM
I agree the one in the white
Dec 9, 2007 | 03:19 PM
Quote:
Monsta,
My trained professional eye picked right up on this for you...
That would be a 5.10 rear you have there...5 butts, 10 cheeks...ALL saweeeeet!
joe.
I wish my truck had that kind of rear end!
I agree, the first two are the best. But either any of them are good. Good post ken
Dec 9, 2007 | 03:20 PM
Quote:
Originally Posted by X_Hemi_Guy
Monsta,
joe.
Which translates to a VERY STRONG rear end. (hence the low gears)
hahaha
Dec 9, 2007 | 03:35 PM
hey guys,
thems some deep rear end gears!
ford ranger
Dec 9, 2007 | 03:40 PM
BTW
do you still need the information on your rear end?
I am sure if you post your info, someone will let you know.
Dec 9, 2007 | 04:21 PM
more than likely it a dana or spicer[same company]. there should also be a tag on your rear diff cover that had the size of the rea diff and what gears are in it.
ford ranger
Dec 9, 2007 | 04:22 PM
sorry fat fingers!
ford ranger
Dec 9, 2007 | 06:33 PM
The axle is made by Sterling. It
does have a tag but there are other ways to determine it without having to crawl under the truck.
1. Door jamb label...some have the code, others don't. Compare the code.
31 = 3.73 Open C1 = 3.73 LS.
33 = 4.30 Open C3 = 4.30 LS.
Use the RPM method. Instructions are in the Super Duty FAQ stickied up top the Super Duty forum.
If it is a PSD equipped truck then it is 3.73 automatically.
