larger cam effect computer?
Old Dec 8, 2007 | 10:40 PM
dixyboy247's Avatar
dixyboy247
I am planing to rebuild my 302 efi and add a mild cam, headers, intake and larger throttle body. How will this effect my current computer settings? The truck is an 1988 f150 4wd 5 spd.Any ideas?
Old Dec 9, 2007 | 05:11 AM
s1120's Avatar
s1120
Yes a cam COULD effect the computer on your truck...if you pick the wrong one. Serch around on this site for SD frendly cams. There are some that work fine with your setup.
Old Dec 9, 2007 | 11:30 AM
i1dery's Avatar
i1dery
Go to fordfuelinjection.com
There you can read up on some stuff and determine if you really need a bigger cam,
and things you should know if you do go bigger.
Old Dec 9, 2007 | 09:46 PM
dixyboy247's Avatar
dixyboy247
thanks for the hint s1120 and i1dery.
Old Dec 9, 2007 | 10:46 PM
THE KING's Avatar
THE KING
What about using a tuner on a SD system so you can put a bigger cam? Just something ive been wondering http://www.fordfuelinjection.com/index.php?p=77
Old Dec 10, 2007 | 08:01 AM
Conanski's Avatar
Conanski
You don't need any computer accessories to run a bigger cam and free flowing exhaust on an SD EFI system. The only requirement is that the cam have less than 216deg intake duration at 0.050" and greater than 114deg lobe seperation angle.
