Fuel woes.......
Old Dec 8, 2007 | 09:17 PM
Relic12's Avatar
Relic12
Fuel woes.......
Not sure where to post this But I have a 93 Ranger Have changed Fuel pump ,fuel filter, fuel relay,checked fuse and emer.shut off switch ...Pump will not run ...except for when it sits overnight will start and run but if i shut it off the pump wont start again....I am not a noob but I am apparently missing something ...any ideas????
Old Dec 9, 2007 | 12:48 AM
Bear River's Avatar
Bear River
Former ******
If the computer does not get a PIP signal, the pump will not engage. Suspect bad wiring or a faulty pickup coil.
Old Dec 9, 2007 | 08:49 AM
Relic12's Avatar
Relic12
It has distibuterless Ign. but will check the wiring today
Old Dec 13, 2007 | 08:10 PM
Relic12's Avatar
Relic12
Found no bad wiring but was told it could be a bad control module as the pip signal goes through it so Im gonna pull it and see if I can get it tested ....any thoughts ???
Old Dec 21, 2007 | 03:25 PM
Relic12's Avatar
Relic12
ok ok Iam an fuel injected computerized automotive noob ....had the codes pulled its a 542 (fp) open circuit /(eca) to motor ground ....where is the eca located on a 93 ranger 2.3L??
Old Apr 1, 2008 | 07:07 PM
Relic12's Avatar
Relic12
I 'm sorry for the really late update but the problem turned out to be a bad ground on the sending unit .........
Old Apr 1, 2008 | 11:03 PM
grizz3000's Avatar
grizz3000
Glad to hear you found the problem!
