Tire and Performance Recommendations
I was wondering what tires people have had good experiences with, right now I am leaning towards Michelin Cross Terrain SUVs – anyone run these and have good/bad things to say.
For performance improvements I want to start with a catback exhaust and a chip/tuner.
It looks like the two options out there (in my price range) are the Gibson and the Dynomax, are there any others? What do people that have these think of them in regards to: sound, power, ease of installation?
As far as the chip/tuner I really want to improve the shift points and get any possible improvements that are available using 87 octane gas.
Finally are there any intake options out there that flow more air but do not have the possibility of allowing more dirt into the engine - like the K&N.
Any other mods I should consider?
The trinity for beginning mods is Intake, Exhaust and then chip. Get more air in, get more air out and then add more fuel.
I have a gibson single out system, it's nice. However, as soon as it begins to fail, I am going with a Corsa system. Corsa's sound is growing on me. Exhaust systems offer little in performance gains on their own.
For tuners, Any of the big names will do what you want. For fords, I prefer Superchips over hypertech and most of the rest. Edge's new evolution is pretty cool though. I am running a Sniper Special Forces and it's the most feature packed, end user friendly tuner I have found, and they have data logging/wide band o2 coming soon.
For cold air, there is nothing wrong with K&N. I have read the bs about them not filtering and I have received a 3 hour lecture on filtering. I still run K&N and do not believe it will fail as long as I put it together correctly. If you still insist on extreme filtering, check out trueflow http://www.trueflow.com/ They are about better filtering without losing flow.
Shift firmness is better done with a shift kit, I am very happy with my Factory tech valve body. It was easy to install and I have returned my computerized shift firmness back to stock. However, with the valve body, I can chirp 1-2 shift.
Gears, depending any tire changes, gear changes can make your vehicle feel thousands of pounds lighter.
One more question, does Energy Suspension offer the endlink bushings for a 2wd truck. I am guessing that this one (http://www.ultrarev.com/product.php?productid=44381) would work. Has anyone installed these?
While I'm not sure where you obtained your info, or how you came to the conclusion the lack of filtering with a K&N setup is BS regarding PSD's, you should know the K&N setup has been proven to be less effective in filtering than the stock setup, the AIS, or the AFE stage 2 setup, as evidenced by studies that have been posted in the PSD forum.
Regardless however, the point is moot since the OP has a V10.
Stewart
BJ Lexington, KY
As for V-10 hp improvements I can only repeat what I have read here....since I own a diesel. I know many have said the exhaust systems do no good as far as any noticeable power or mpg's....they definitely do not respond like the diesels do with mods. Just know buying mods for the V-10 will = less power than say a diesel. So for hp's per $dollar spent it might not be that great of money well spent!!
All I can say is STAY AWAY FROM K&N, for gas or diesel engins!!! I have spent $$ having my air intake, throttle body and various sensors cleaned on my gas motor because I used that K&N crap........stay away for sure!! I cleaned my K&N religiously, doesn't matter it will let dirt in for sure!!! Read around a little bit I think AFE is a better setup, others will chime in on this one for sure!!
Maybe there is a supercharger available for the V-10, I am not sure but spending money on other mods might not be money well spent if you are expecting a lot of extra power!! GOOD LUCK with your EX!!
I've averaged about 80,000 miles on the Michelins. I rotate/balance them at 6k - 10k intervals.
BJ Lexington, KY
They have full all weather grooves (no wear bars at 50% tread left).
They also come siped from factory for winter traction.
The Michelin LTX M/S are also a great tire (my dads truck)
Don't put cheap tires on because you will get what you buy. Junk=Junk.
Go load range E especially if you ever plan on towing anything.(they are about $40/tire more.)
Go to the V-10 forum and you will see that most tuners for the V-10 are not worth their cost as the factory tune is about as good as it gets.
Spend that extra money on suspension modifications or toys.
Your creature comforts will make up for any lack of performance which are slight considering you drive a 4 ton beast.
If you wanted a race vehicle you should have bought a car or a diesel Ex.
Welcome to the Ex family, Rich.
i will most likely put Michelin's on my X as well, but don't know what mileage to expect with it being a 4x4 and the van 2wd... i do check tires often and listen to what they tell me as far as repairs and adjustments...
my only problem with tires is, i am cheap and won't replace them if it's not needed... by then sometimes the tires have a higher value than the vehicle...
I don't run them in the Winter any more since I am a firm believer in Winter Tires for best performance in cold weather. They tires are great though. They ride and drive well and wear like iron with my 2002 Exucrsion with 7.3L PSD.
