8 inch rim backspacing
I currently have 305/75-16 MTZ's on factory alcoa rims and the right front rubs on the spring at full right lock. I want to eliminate the rub and be able to move up to 35's but i am not happy with 10 inch rims. Will 305's on 8" rims rub? Has anyone tried 8" rims with less backspacing? Thanks for the help. scot
2001 crewcab 4x4 F250 diesel.
My thinking is 305's are the same width as 315's and alot of people run 315s on 10 inch rims. This moves the center of the tire out 1.5 inches from stock( 7" rim) so if I went with one inch less backspacing on an 8 inch rim the center of the tire would be the same as with a 10 inch rim. I prefer the profile the 8" rim gives over the 10" but I don't want the spring rub I'm getting with 305's on a stock rim.
