Sponsored by: Real Truck
Possible ball joint needed
Old Dec 7, 2007 | 06:22 PM
XLnAK's Avatar
XLnAK
Smile Possible ball joint needed
Hello , My 04,crew f350, has a new sound. After listening to it for acouple weeks , I finnaly had the 13yr old sit in the driver seat and move the powered up steering back and forth afew times ,I found the source of the tiny symphony to be the lower ball joint. Its making a crisp rapid creeking sound. Pinpionted with a mech stethosope.
My question though is, to what exstint this sound generation is actually indicating a bad joint. I,ve replaced balljoints on my 84 1T before, but never had the joints chatter like this before or after replacment? The stock units on my rig are nonserivicable units , but in a feeble attempt to remove possible seal source i did apply some penitrating oil. Yikes.
Old Dec 7, 2007 | 08:41 PM
XLnAK's Avatar
XLnAK
Hum. Before submiting this thread and blasting off to pick up the kids , I hadn't gotten to read prev. threads. . Sounds like replacing the balljoints is a safe bet , But really , as creeky as it is ( only for about 1/2 or 3/4 of full turn from center both ways ) does anyone thats replaced them as soon this starts found the joints in terminall mode , or just slightly dry ? Should I enlist a pry bar to check looseness at this point or can this creek most likelly chill till spring?
Through other threads here. I have found some real informative documents on things like, hub servicing , brake replacement and such, does any one have a walk though for balljoints, documented with pics, link available for viewing?
Thanks for a great Forum.
Old Dec 7, 2007 | 08:58 PM
elmo8641's Avatar
elmo8641
the ball joint on the drivers side would creak. i bought a grease gun needle at advanced auto parts for $3 and injected grease into the ball joint. noise is gone. its been about 9 months now. may not be the best fix but it worked.
Old Dec 7, 2007 | 10:50 PM
Jim59's Avatar
Jim59
Here you go ..... RacerGuy's step by step, with links to photos .... many people here on this forum , including me, have used it, and RacerGuy did a great job ...
https://www.ford-trucks.com/forums/3...ll-joints.html
Many people on this forum, including myself, have used this guide, and it's great.
Good luck.
Old Dec 8, 2007 | 04:23 PM
XLnAK's Avatar
XLnAK
Thanks , I had totaly forgot I had the needle adapter for my grease gun.I last used it to flood a set of sealed snow mobile bearings. The link looks great. now, for the read.
thanks again for the heads up.
