Has anybody every come across what this engine will burn in fuel while idling? I am trying to justify installing a Webasto or Espar coolant heater instead of remote starter.
I have read before that 1 hours of idle is equal to 33miles of driving. not sure of idle speed (high idle) i am sure someone will chime in on this topic soon
I do have the high idle mod on mine, and when I am idling for any time at all I normally turn that on because these engines dont like to run at a low RPM for any length of time due to wet slacking. Anyways, I know mine seems like it draws A LOT! of fuel while it is idling.
Also, I have a 1500watt inverter that I use to power four 8' lights in my trailer, and I normally will idle the engine when I am loading or un-loading with the lights on. The worst I have seen it was 1/4 tank over about an hour and a half, other times it is much less....
There was a thread in the Super Duty forum with a Diesel fuel usage calculation from Ryaneverk2. It was a while back this year and for the 7.3, but it would give you an idea.
